and it aint piggy
'89 xj
squeak squeak squeak while the engine is idling
sounds like its coming from the center front of the engine
at idle, it squeaks maybe 4 times a second..doesnt seem to correlate to any of the pulleys, which are spinning much faster..or am i wrong? lets see idle rpm of 900, so thats 15 revs per second...about 1/4th of that speed would be the squeak speed...maybe it is one of the pulleys....
the squeak goes away instantly if you just BARELY open the throttle and raise the idle rpm up a few hundred rpm
or maybe the timing gear area?
'89 xj
