- MilkyWay Galaxy
Update, using 8Muds hose clamp diagnostic test, I got mush for the peddle after closing off the passeneger side hose (the one with a new caliper and hose, that this test showed had a bad caliper or hose). Blead all the brakes again, and retested, same thing. Then tried clamping off the drivers side hose and got a hard peddle, so bled that side again, then clamping off that hose again got mush again? The hose clamp test is not giving consistent results. Also noticed that in one clamp test the wheel would no longer turn, in the other clamp tests the wheel did turn? Both hoses are new. Scratching my head again. I have good brakes, but a deep stroke and mushy peddle still. Maybe it needs new muffler bearings?
WE do have solid wheel lock up off the ground on all 4 wheels with about 1" of brake peddle travel, and I can lock up 2-3 wheels, maybe 4?, and skid the jeep in a panic stop if I go heavy and hard enough on the peddle now.
So this weekend we clamped off the passenger side brake hose, and bingo we had a solid peddle with engine on, vacuum to the booster on.
I had already procured 2 new rotors in desperation to try and we replaced the front rotors on both sides and got no change in the brake peddle mush.
So we ran the hose test and got a confirmation the passenger side front was the source of the mush per 8muds suggestions.
So I procured a rebuilt duralast (LOL) caliper and new hose. Bled that caliper and the combo valve ONLY. Still mush?????
But now I have great brakes, it just takes a 3-4" stroke to the floor to get there now?????
Now I am really puzzled!!!!
I plan to bleed the entire system again tomorrow, but I figured the rears would not get air (combo valve block it to the front?) , but perhaps that is wrong?
Any thoughts front the gallery here about using a real vacuum pump and a spare MC lid to make a vacuum system to bleed (suck) the air out from the top side all at once???? Can the closed system handle that much vacuum???? Or should I use a limited vacuum like the el-cheapo ones that Harbor freight sells. I can supply nearly 30" of hard vacuum with my large lab vac pumps, or my AC professional vacuum pump, but they might suck the seals out the calipers or wheel cylinders unless they are designed to handle it??????
