Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Great idea! I'm also thinking that your idea of taking a old brake light switch and using epoxy to hold the pin in place would work. Or, we could cut the top off, remove the spring and force a small bolt or screw through the top to hold the pin in place, then screw the switch in. It should work since the switch is plastic.
Just be careful as the old brake light switches are very brittle at the thread area. I need to easy out one already that my buddy broke off in the combo valve
Thanks for reminding me of the used brake light switch and epoxy idea.
