Socal Karma Thread
Status
Not open for further replies.
Re: 2013 Socal Karma Thread
any chance you can get me some dimensions on that airbox? just the box, not the tube or anything.
Stock coils and shocks, the front shocks look to be newer.
Get them before they hit the trash can next week.
Also have a working refrigerator that would be good for a garage shop blah blah. Leaks water every once in awhile I believe its from the defrost cycle maybe needs a new drip pan or something. Needs a good cleaning that's why's its freeeee.
97 and up driver's interior door panel for a 4 door. All black, no electrical, no switches, no panel snaps.
This thing is pristine, I'd give it a 9.9 out of 10...
You must come get it, I live in Tustin.
Guess from what is written that it is for power windows/locks? If manual, I want it.
I know on my 89 and 94 i can use power or manual door panels, couldn't see any difference at all. I don't know on newer doors if they changed the switches any or they all all still in the same place.
Your manual handle and cover will bolt right in and in the back of the panel you'll see where to punch the hole for the manual window crank.I have done a set for my jeep.When all said and done you'll not even know this was for power windows.
HTH
stock fuel tank from my 91 xj. may be a little dented at the bottom, ill have to pull off the plastic skid to confirm. doesnt effect much.
OK, I guess i could have gone out and look at my 97 sitting here.LOL, just to lazy.
Sorry i couldn't help him.
With later model ones, I suppose could make a hole for the crank apparatus. But then, I would either have a power switch that doesnt work sitting there on the arm rest, or a hole. Unless they made a cover that fits in the same spot.
Random stuff I've gotten via Karma over the years. Many items for 1990ish XJ. Some may not be XJ at all.
All parts currently in my back patio off the I-15 & Hwy 52 in San Diego. I work in El Cajon on Tues & Thurs, and Carlsbad on M/W/F right now.
I have every intention of being at SoCal Fest in 2 weeks. I will also probably be traveling up the 15/215 this Saturday, and might be able to drop something off if it's close to my way up; I'm not going north of Hwy 60.
Front bumper brackets (stock, I think, but I'm not sure)
T-case shift lever assy, with bezel that has 2WD, and then Hi Lock & Lo Lock in 4WD
Fixed aftermarket lower (only) control arms. Could be RE, or who knows. Red poly bushings.
stock diff cover
aftermarket tow hooks (2 pair)
small fluid cooler (power steering, I think)
rear wiper motor
front wiper motor
Washer fluid reservoir
Coolant reservoir
My toes not included...
Stock 6-blade electric fan
Pre-97 fuel pump assembly WITHOUT the actual pump or strainer
Cruise control (I think-- at least that's what it looks like to me)
ONE aftermarket headlight
Dirty K&N stock style air filter
Stock spare tire cover
Stock rear cargo area cover, no brackets
stock scissor jack
Window glass: One rear side (factory smoke tint), both rear doors+fixed vents (factory smoke tint), both front doors (untinted).
Stock track bar
Stock Y-link
Stock battery wiring harness for 1990
Header panel, no grill, etc.
Bucket o' MJ interior trim miscellaneous. Stuff I forgot to give JohnX, and now he doesn't want it.
Stock R-12 A/C Compressor, I was told it was in working condition.
hey carol, I'll take the washer fluid resi, the shifter linkage/bezel and those bumper brackets.
I can come pick them up from your place some-time.
also, I have a set of OEM rear nut-strips I'm not using if anyone wants.
I'll take the rear wiper motor if you're able to schlep it to SoCal Fest (and also if it works for a '99?)
Carol if nobody takes the arms i would like to have them for my pile of parts for folks out here.I am all out of them now.I can have them picked up at BB.If i get his jeep finished, waiting on the rest of parts to show.
Thank You
P.S.
I'll also take the shoe's, you can keep the toes.
Thank You again.:)
If they aren't already spoken for I"d like the bumper brackets, a set of tow hooks, and those triangular brackets with the tow hooks.
Ill take the arms, fan and bucket o' MJ parts... oh nd the ac compressor... can I meet you on the base of hwy 330 on your way up to BB. I really need all of these!
Status
