Mike L said:I assume the seats are the standard highback seats? And not the Laredo ones?
-Mike
Correct, cloth and vinyl
-Mike
Bent said:Well, I've been up to the same thing, thought I'd already shipped off quite a bit, however I missed one item. Oops, two.
GONE OEM TJ: pair of fog lamps with the harness, Blinker lever/switch pod and the instructions. The lights look as though they have a few miles on them, the rest of it is brand new.
GONE 1 ea. OEM Radio,Cassette/CD. This unit is out of a 2001 XJ.
Spoken for: 3 ea. Factory speakers out of '01 XJ. I SWEAR that the fourth one is sitting around here somewhere. I give up.
1ea. '01 XJ OEM white rear bumper only. No brackets or end caps.
1 ea. '01 XJ OEM tire/cargo cover. The tire cover is tan carpet and the cargo cover is tan canvas.
GONE *4 ea. OEM 15 x 7 aluminiun "Ecco" wheels. Scratches and small dents but they are round and balance fine.
GONE *1 ea. 31x10.5x15 BFG (not KO) ~40% tread on balanced on 15 x 7 OEM steel wheel. Good for spare, that's what I had it for.
GONE 1 EA. '01 XJ OEM air box.
Well I think that's pretty much it. Looks like I had more $h!t than I thought I had. All are subject to Scott's rules, whatever they turn out to be. I'll ship to red letters.
:idea:BTW, good idea ya got here Scott.
TIM
* available mid to late Aug.
Bent said:Update: I have found the garage floor!!
arty: arty: arty: arty:
Blazair said:Bent, I'll take the rear bumper from ya.
-Mark
ROBERTK said:got a new bender and 1-1/2 die set< Nope not giving that away for my life. But I am willing to use a guinea pig rig for some cage work. I have done add in PSC cages in the past adn a full fab cage in my own rig but never with a bender.
All my past work has been in TJ's so if your looking for some cage work and have the cash to furnish all the tubing and consumables, And are not some high stressed overly critical junky then hit me up if you want some bending / welding / cage work done. I will take on at least two projects before I will cancel this offer.
Keep in mind this WILL involve waste matierals and you Will be buying more then you need to allow for waste / screwups in bending. But I will say it wont be alot. Schorr metal is local enough and cheap enough though.
Rob
[email protected]
yorba linda, ca
damn, how many jeeps do you have?Captain Ron said:I've got an 89 MJ and a 89 XJ that will be stripped almost complete, buggy projects. Need something?
I also have a 98 that will be donating the engine and trans, the rest goes.
By PM's please.
--ron
Kejtar said:damn, how many jeeps do you have?
