So Cal desert rats
Thank you MIKE
I hope i make you smile today..
I really liked this butcher block look, and , I am guessing, it sat outside for a while. So the top cracked in a few places, which added to the distressed look. But it also raised some of the grains in some of the blocks. I needed to be able to write on this top. So I wet sanded the tops first coat of lacquer and proceeded to add 11 more. I wet sanded again after the last coat and began the polishing. 10 coats of wax, power buffed after each coat, was added until I was happy. The 12 coats of lacquer smoothed out the top to a glass like finish. Added some pulls to tie it into the decor of the house, and done.
Thanks Again, Guy's!
Thanks!
Scott, we'd need to use bondo with Kevlar to fix your body. :gee:
