Snoring...
chad
lancaster, CA
Ok guys,
I guess I snore pretty loud sometimes.:explosion I feel bad that it messes up my wife's sleep and I want to find out how to stop. Any of you guys/gals had issues with snoring? I've found all kinds of junk on the internet, but what really works???
TIA
Chad
:D
Seriously though, I've tried the stuff you spray in your throat, and it didn't work. I had mixed results with the strips you stick on the outside of your nose. The wife noticed about a year ago that I only snore when I sleep flat on my back, so now I lay on my side and seems to have done the trick.
My Dr. put my on a steroid nose spray for allergies, that has helped to some degree by just opening up my nasal passages. Sleeping in a more upright position seemed to help as well.
Have your Doc run a sleep study on you. You may have sleep apnea. If you do, it can shorten your projected lifespan by 10 years.
I sleep with a cpap machine and I feel tons better.
Talk to an ENT. CPAP isn't the only answer. You might end up with a mouth piece to wear at night.
CPAP worked for me using a nose piece. Not too intrusive, but wish I did it YEARS earlier. One of the BEST things ever in my life. I know very thin people who snore like freight trains. You will have better sleep, I did.
Agreed, I am 6'3 and 180lbs. Snore pretty dang bad.
You may also need:
- RF Turbinate reduction. Turbinates are the tissue immediately behind your nose - they can become inflamed. I had this - it helps (turns out the doc that did the procedure on me was the one that developed it.) It's an outpatient procedure, takes about 15-45 minutes (depending on how much reduction you need. I had four sites bilateral and was done in 20-odd minutes.) The inflamed tissue is coagulated with RF energy (akin to how a microwave oven works) and is purged by the body over the next week or so.
- Somnoplasty. This is a reduction of the soft palate (back end of the roof of your mouth) and uvula (pink dangly thing at the back of your mouth cavity) - which I'm in line for - just haven't been able to have it done yet. I don't know what's involved in this, because I haven't had it done yet.
- An EENT, pulmonologist, or GP should be able to order an overnight polysomnography (sleep study) - the problem I have with having them is that they want to do them at night - bed around 2200-2230 and wake around 0600. I'm nocturnal - I don't usually go to bed until 0600-0700, so they're not catching me when I sleep.
Other conditions may apply - I have major post-traumatic chronic sinusitis, and take several Sudafed every night before I go to bed (and work on a couple of Hall's until the Sudafed kicks in.) Even so, the crud that I dig out of my beak every day after I get up could stick a loaded bookcase to the wall, and there's a lot of it! Typical routing on waking is to root around with Q-tips until I get most of it out, then build up a good head of steam in the shower to loosen up the rest. What I get usually resembles rubber cement, but there aren't any signs of infection (it's even been cultured to make sure - it's not the product of an infectious process, just chronic irritation.)
Most of my breathing issues stem from massive facial trauma (stellate fracture of faceplate, from just below nose to hairline, and full-width) and the resultant aftereffects. You probably don't have as much wrong with you as I do with me, but it's worth checking into. Do you have clogged up nasal passages when you wake up? What colour is your mucous? Is there a lot of adipose tissue around your neck? General physical condition? Muscle tone?
Chances are good your MD is going to ask these questions (or try to determine answers for himself,) so you want to chew on the answers anyhow. They're important, so you're going to want the answers to them before you do anything else.
(Side note - CPAP can help, if your condition warrants it and you can tolerate the mask - I'm told they can be quite comfortable, my wife uses one and my mother-in-law did.)
You may also need:
The Google ninja strikes again.
I don't think there is any easy cure. I'm 6'6..225, cetainly not overweight, but am a tad out of shape. I snore...on my side, on my back.
I have had 2 sinus surgeries and neither one worked. The issue with the surgery is that when you cut back the turbinates, they still will expand and swell, they just have more room to swell and will swell bigger.
I also did the palate hardening. They basically shoot an acid into the soft palate and allow that acid to eat into it and create a scar tissue, with the idea that the scar tissue will be harder than the palate was and lessen the vibrations that can occur.
I tried the spray, tried the strips. I even did a nasal wash for awhile. You use warm salt water in a bottle, shoot it up your left nostril and let it drain out the right, then do the same thing in reverse.
I would suggest the sleep study. It can be very valuable. I was able to learn quite about it about my sleep patterns, but not what was or wasn't curing my snoring.
If you snore only on your back, which is the bulk of my snoring, it was was suggested to me that at night I place a tennis ball on the small of my back and hold it in place with an ACE wrap. The idea being that when I rolled over, it would cause discomfort and my body would instictively roll back to the side without waking me.
It is one thing to throw potential solutions on a Jeep to "see if it works." It is quite another to just do random surgeries to see if that makes a difference. I would recommend trying all the non-evasive options before opting for surgery.
We finally put trying to hunt it down and spending money on dead ends on hiatus. For us, it works simply to sleep in different rooms.
Only good thing that came of this is that I got to see Keith Urban at the office once. He and I share an ENT and we had appointments at the same time one afternoon. I was getting my snoring checked out and he was there for a throat check up before heading out on tour.
No Googling - just what I've been dealing with on my own.
I honestly wish I could download my brain and defrag it, then plug in an efficient search end for the front-end - it would make my life much easier...
There's just too much stuff in here to keep track of anymore!
I had a sleep study done and it really told me a lot about my sleeping patterns. Horrible snoring, exhausted, getting up every 2 hours to pee, wanting to fall asleep while driving home (especially when it was really hot or dark outside) and poor attitude.
They issued me a CPAP machine with the nose pillows. I have never slept so well. My number of incidents were throught the roof. Now I only wake up a few times during the night and never have to get up to pee.
According to my wife I snore alot as well. I did the sleep studies and was diagnosed with mild sleep apnea. Got a CPAP with the nasal pillows. I'll be the odd man out here and say I HATE the thing. The only thing positive it did for me was eliminate my snoring 100%...so the wife was sleeping better. I on the other hand slept worse. I didn't wake up feeling any more refreshed in the morning...the only thing I woke up with was a sore nose. I tried it for a few months and got to the point where I chose sleeping on the couch instead.
Now what has helped me the most is weight loss. I'm a short guy, 5'7"...and about 12 weeks ago I weighed 207...as of this past Saturday I was 180...so I've dropped close to 30lbs. The wife says I snore MUCH less.
Also, I'm a drinker, 12 weeks ago I was drinking 5-6 nights per week...that also contributed alot to my snoring. Now I've cut back to only 1 night per week. So some lifestyle changes and a significant weight loss and the wife and I are both happier.
