- MilkyWay Galaxy
1985xjlaredo said:Wow those are some pretty substancial p.s.i. gains for just fooling with liquids. So when are you going to do a stroker?
In my work vocabulary its called a significant increase, not substancial, but for now I won't quible over technical words, LOL.:clap: As Darth Vader once said, "Impressive, most Impressive"!
I am just tickled pink at how impressive the gain was for such a short time, less than 3 hours after adding the snake oil mix. No stroker plans, this was on my sons 3.0 Ford Taurus, 198,000 miles, and it had started throwing the misfire code right after the radiator hose busted doing >60 mph on the freeway. The car died immediately from the coolant loss. We thought it might be a headgasket going out, but so far the head gasket seems to be OK.
ehall said:What's the daily usage pattern on this vehicle? If it is all short trips for cigarettes and milk then the engine is not spending a lot of time in closed loop mode and will likely have a lot of carbon buildup. If it is used for commutes of 20 mins or more, then it likely suffers from scarring. They are different problems and require different solutions, the former needs a good cleaner like Auto-RX (top-end cleaner and carb cleaner helps some too), while the latter needs an engine treatment like Restore to help rebuild cylinder walls. It sounds like you are seeing loosened deposits so I'm guessing the former more than the latter, but it could be a combination of the two.
Right now the daily usage is sitting in the driveway running snake oil repair tests, LOL. But seriously it got 20,000 miles of heavy use the last 12 months. A good mix of long highway drives, and city commutes. It gets to Closed loop in under 1 minute from a cold start up according to my scanner. The old plugs which were worn out from .042 to .055 had very little carbon on them, in fact they looked pretty good, just worn. The new plugs were totally carbon free after the first 3 hours (no snake oil just new plugs and wires), before doing the snake oil thing.
Right now It could be any one or combination of three things that did the trick, (1) coolant head gasket sealer, (2) MMO plus Restore plus fresh oil cleaning the valves and piston rings and plating out in any low areas or scratches to reseal the cylinder and restore compression, and or the 2 cans of carburator cleaner I ran through the intake manifold.
All I know, is I got a lot more than I expected for 3 hours out of my snake oil mix.:clap::clap::clap:
