Smaw welder circuit breaker trip.
smokskrene
Maine
I picked up a what looks to be Russian SMAW welder from a coworker. It was her fathers who as recently passed away. I am very handy and with plans to chop my bike over the winter, I couldn't say no to the welder. I have never welded before but have done plenty of research.
I put a new plug on it, it had power, but nothing from the electrode. I opened it up to find that he had tinkered with the wiring. I reworded it to stock and eureka!! It works!!!! It's bittersweet however. So here's the problem...the sticks that came with it feel damp. They have a white powdery residue on them. I assume they are bad? I only have a 110v outlet to work off FYI. I started on the lowest setting and I can spark the electrode but can't maintain an arc. I turned it up and had the same problem. If the electrode sticks it trips the circuit. What to do? The circuit is on a 20 amp breaker. I was planning on switching to a 30 amp one as well as try new sticks.
Suggestions??
Thanks!!
First and foremost, circuit breakers are sized to protect the house wiring, nothing more. If you put a 30 Amp breaker on 20 Amp wire and start a fire, your insurance company will have grounds to refuse any claims.
Second, take a picture of the input and output voltage chart, and post it here.
On the welder: It should tell how many Volts, Amps, and Phase, AC power that is required, and the Volts and Amps output, in AC, DC, or both.
First, that unit would be much easier to use if you had 220V to feed it.
Second, it would not hurt to replace the old 20 Amp breaker with a new 20 Amp breaker.
Third, if you are stuck with using 110 Volt supply voltage, buy 1/16 welding rod, 6011 if you can find it in that size.
Also, when you try to start the arc, try dragging the electrode across the metal, like striking a match. When it starts to spark, lift the electrode off the work about the same distance as the diameter of the rod.
So I have adjusted amp settings, and have had fun so far. I practiced running beads but kept tripping the breaker. So I decided to just have fun until I can decide on what to do with accessing 220v outlet.
Cool! What kind/size of welding rod are you learning with?
I bought some 1/16 and they burn so fast. Like like 40amps would be better. I can only get down to 60. They glow after a few. So I stepped it up to the next biggest size that I have. I'm not sure exactly what kind they are. They were given to me in an opened and in labeled box.
