small issue any advice?
dirtbagXJ2103
so i just put the RE track bar drop with hd track bar and brace on my jeep and the jam nut on the track bar is hitting the diff cover with more bump travel to go still. its a 4" lift with 7" of bump i have 17" C to C lowers and stock uppers, so i could notch the diff cover? or if i install control arm drop brackets would it swing away and tuck before it hits? WTF? thanks
your only at 4 inchs I would say the track bar drop bracket is pushing your track bar to far down... I could be wrong here but I think then bracket is to be used at 5+ inchs of lift? or maybe your front axle is pushed fowards for some reason?
yes stock diff cover, but i noticed the axle housing above the cover is hitting the track bar johnny joint i have about 1 1/2" of shock left on that side when this happens
GetAttachment.aspx
