hubs97xj
- Fort Wayne, IN
Since when are details relevant in a technical discussion?
Funny but no one asked what tire size, gear ratio, road conditions and load you are carring in the XJ,...or did I miss that?
Any updates or solutions for you? I'm in the same boat as you and sounds like the same problems. When my transmission heats us ('96, 4.0, AW4, NP231 w/ 247K miles) the RPMs start climbing and my speed drops off.
Today as I pulled into my neighborhood I was hitting about 2200 RPMs and coasting down the road in 4WD. This huge snow storm we've had in OK has had me running around in 4WD for about a week straight. More than I ever have in the past. I did notice when I got home that my trany fluid was a bit overfilled. I drained about 1.5 qts and now it's at the low end of the 'check' bracket. It also smelled burnt but still looks pink. I just did a 3 qt tranny change about 4 months back so the fluid still looks good. I also checked my cable adjustment as mentioned here and it was good.
I REALLY don't want to pull the transmission and swap it out w/about 12" of snow and ice around. Not my idea of a pleasant experience.
I just had this happen with the used transmission I we put in a 96 XJ. I had only driven it maybe 150 miles has fresh oil and filter. ATF-4 though which reading other threads could be an issue but fluid level seemed fine cold but when I checked it hot it was a little over filled. I haven't tried any of the adjustments mention previously but hopefully they work or I just wasted a few $$$ replacing my old transmission.
Why would the brake switch fix anything to do with the transmission? it's function is to control the brake lights and shut off cruise control if equipped.
