Yes, but you can make spacers very easily and they put the skid down far enough to cover the TR.
I have mine lifted about 4" and the skid dropped 2", so everything is covered perfectly, and is well worth it when a rock smacks the skid and not the TR.
Don't waste the plate though. I coverted mine into a xfer case skid that covers from frame rail to frame rails.
Directions:
1. Cut the mounting end tabs down about 3/4" the way down
2. Weld 3x3x1/4 angle on each side. (flat side up)
3. Drill and mount angles along the frame
You have to flip it around- Front of skid plate should be the rear and the rear should rest on rear of the xmission cross member lip.
