Site doesn't load from home computer
basalt51
NAXJA Member #761
Woodland, CA
Within the last week or two I have been unable to load the website from my home computer (winXP home ed.). I just get the website not found or microsoft search engine website instead. I've tried deleting all my cookies, history, temp files etc but it doesn't work. Other websites load fine.
Any ideas?
Sounds like the network congestion issue is cropping up again. If it'll load from work, and not from home, it's not in the NAXJA servers.
I"m not familiar with the network congestion? That only effects NAXJA site?
I figure its one of my browser settings or something, I just don't know where to start or what to change. And it never loads for me at home.
It's not NAXJA specific, nor is it specific to you.
Here's a quick and dirty description of network traffic:
Your computer is identified by an Internet Protocol address (IP address.) This address is used to figure out what is close to you (in network terms,) and what needs to be sent through a gateway to get to another machine.
So, let's assume you're at home, and have a browser open to the NAXJA website. Your computer will send out a packet to your local gateway. For broadband folks, this will be your firewall/router. Dial-ups, this will be back at your ISP. At the first gateway, aka "hop," the packet will get forwarded to another gateway closer to the destination. This process continues until the packet gets to the router next to NAXJA's server, or it gets to 30 hops (by default.) The return packets happen the same way.
Network congestion happens when a link gets more traffic than it can handle. Depending on how the router is configured, some packets may get silently dropped, or they may get returned with an error.
I suspect that some of the major backbone routers are overloaded, and packets are getting dropped. This is probably the worst case. It's actually overloading the server, because the connections are being held open, and retransmitted.
In short, I doubt there's anything that you can do. I doubt there's much that I can do either, except let NAXJA's ISP know when I identify a congestion issue.
