Sierra "Karma" thread
I have a set of 15X8 steel wheels, chrome, but could use a black rattle can paint job. Weher in a XJ, I have no use for them. Not sure of the backspacing, but I can measure, I think I have 5 of them. located in the East Bay. Good set in decent shape and FREE. if you can donate a toy for teh tos run appreciated.
Toys for tots already bought for... will take the wheels if ya still got em? WHere are you?
dana 35 3.07 ratio free to a good home. The brakes look to be pretty new.
I have benefited from this thread several times now and need to get some "Karma" refill! I have a whole bunch (as in 20 plus boxes) of brand new WAAG industries step bars for various full size American trucks. If you want to use them to make your own they are almost all powdercoated with treads for four doors, so they are weldable. I will give them (happy to look at trades... but will gladly give just to clear space in my garage) to whoever wants them.
Tim, will pm you. Do you have anything for a F350 4 door?
Thanks,
Gui
Yes, I think so... may take me awhile to dig up the options.
How 'bout the rest of you guys? No need for these on your pickups?
all from a '92 4.0L:
Stock Master cylinder (ABS)
Stock Booster (ABS) <<<------ if no one NEEDS this, its got a $50 core on it... so let me know ASAP if you want it...
ABS Computer / fluid controller thingy
Cruise Control module and stuff
AC Stuff: Condenser, evap canister, hoses - everything but the compressor (till I can get the replace-a-compressor pulley)
Stock coolant overflow bottle
Hey ill snatch the coolant bottle and the ABS stuff. Ill send you a pm.
Sean
Can't you convert compresser to OBA?
Dana 44 drum brake backing plates. Dana 44 lsd carrier for 3.55 and numericaly lower gears with no bearings/ 3.07 ring and pinion. Hard break line for the 44. In a week or two complete 35 non c clip with newer brakes and rusty's rear shocks for a 3-4 inch lift. All located in Yuba City.
Are those backing plates the bearing retainers?
No, I should have been clearer now that i have read it again. These are the mounting plate for the drum brake assembly. Not the bearing retainers that people refer to as backing plates. Sorry for the confussion. Also im leaving to go get some new 33'' mtrs in a few hours so if anybody wants a free set of 31x10.50.r15 bridgstone m/ts they are all yours. 3 of them have about 50% tread, the other one is a little worse for some reason. I will store them at my place in chico for a few days if you promise to pick them up. Otherwise they will stay at the tire shop.
Here's a list of free things to a good home:
-Stock steering (good for a trail spare)
-All interior body panels from the cargo area (plastic) Grey
-Carpet from the rear of the driver's seat to the back. Grey
-Cargo area liner (black)
-Back seat (grey)
Happy Thanksgiving!
Hunter
Figured I'd post some stuff!
All parts located in San Mateo.
-zj front v8 coils
-xj front coils
-xj stock lower control arms, good bushings
-Decent rear xj leaf springs, with RE short aal.
-1 stock rear drive shaft, off of a 2000.
-2 xj track bars
-3 stock brakelines (fronts/rear)
-A set of xj rear leafs, disassembled, now separate leaves
-4 RE twin tube shocks, for 2 inches of lift, one is blown, but not leaking.
I'd appreciate a good deal ( not asking for free) on a dana 30 High pinion axle, or a quality xj front drive shaft in return!
