What valving?
I have a 1997 that I have built mostly for rock crawling. I have RE 4.5” coils up front and Deavers in the back. I do drive the Jeep to trails, which can be 500+ miles of highway driving. I also drive in the desert, but not too often. Any help in the woops would be great.
I have acquired 4 used rebuildable shocks and all 4 need to be rebuilt.
For the front I have 12 inch Bilstien 7100 remote. For valving, I looked at this on the Bilstien website:
http://www.bilsteinus.com/uploads/tx_templavoila/OffRoadCat_07.pdf
For “rock-crawler / Jeep – Coil Spring”, they recommend 360/80 for front. For both “full size truck/SUV” and for “mini truck/SUV”, solid axle front, they recommend 255/70. What would you recommend? Will 360/80 be too stiff for highway driving?
For the back I have 10 inch Fox 2.0 remote. For these I cannot find any recommendation on valving anywhere. I run the JKS cross-over shock mount and raised axle side mounts. So my shocks tilt inward. Because of this, I assume I would want to go with a stiffer valving since the shock is less effective at an angle. What valving would you recommend?
The Fox shocks both have pits/nocks in the shafts:
I assume I need to replace both shafts... The shaft with the most nicks/pits is also quite a bit softer than the other with less pitting and the pitting isolated at the end of the shaft. I assume that those nicks/pits will damage the seal. If so, should I see oil coming out of the seal?
I know I can get parts for the Fox shocks onlin at Poly Performance. But, I cannot find any place that has Bilstien parts and rebiuld kits online.
Anyone know any place I can get Bilstien parts online?
One last question, can anyone recommend a place in San Diego area that I can get these shocks all charged with nitrogen?
Thanks.
Thanks.
