There are probably a bunch of similar discussions regarding this but I haven’t found one yet that is exactly what I’m looking for.
I picked up a ‘91 this year. First XJ but hopefully not the last. I’m using this one as a winter vehicle and a commuter. So far I’ve put 4,000 miles on it and it handles my 70 mile a day commute well. I’ve been picking away at things on it trying to walk the line between keeping it functional as a winter vehicle but not getting to deep into it. So far its gotten a new gas tank and brake lines due to leaks, and general tuning up and maintenance. Shocks are next on the list.
A few weeks ago I pulled out the rear shocks and replaced the worn out bushings that were thumping. Experienced the usual broken shock bolts and put everything back together using the brackets that replace the welded nuts. While they were out I was able to measure them and confirm that it needs shocks. The passenger rear is providing pretty much no damping anymore. The Jeep has an old Rusty’s lift that is about 4 inches. Rear shocks measure about 15.5” compressed and 25” extended. Looks like I can pick up Rusty’s shocks for $38 each. The question is are there any other budget price shocks worth considering before I call Rusty’s? The goal is to keep this one on the road and improve it for now but not take too much money away from the next XJ that I plan on building or my other Jeep that is resting for the winter. Walking the line between function and cost. Right now any level of function will be an improvement. I’ll do rears, then move on to fronts.
Any suggestions? Especially for something that I can pick up over the parts counter? (Like my front sway bar extensions that came from a Ford van?)
