Shock Placement
iaml3lue
mahwah
So I'm about to swap a new set of axles in. Last set I just mounted the shocks in a stock positions, but this time im wondering what you guys are doing and how its working I'm going to be using tnt's U-bolt eliminators again on the new rear axle. i have no problem cutting the truck but i have to keep it streetable
I'm on stock axles, but I'll chime in. On the front I run stock location on the upper, but on the lower I run a BPE I came up with. On the rear, I run shock hoops and the lower mounts are on the spring plates...
Fronts
Rear. Yes, I caught my seat on fire. I added a brace between the hoops also.
