it's possible. in my opinion it is very borderline on safety. the only way I would do it is if the shim and block are both steel, then I would weld them together and to the perch. you wouldn't need to weld much, just a couple of 1" welds.
Look for the steel shims by skyjacker i think that use the leaf spring center bolt to hold them in place. and use steel blocks... the trail masters blocks used to come with the 2 deg in them already..
