Nickster
- Charlotte, NC
2 problems: What degree steel shims do u think i need for a lp 9'' rear on a 2000 xj sport about 8'' of lift?
And, I have at least a half inch play in my upper control arm on the axle side causing a lot of unwanted axle movement. Should i do poly or rubber on this side, the rubber one seemed to warp rather quick. (BTW its the RK 3 link susp. system). Thanx in advance for the help.
