xjguy98
- Belleville, Ontario
anyone know how to separate the upper shifter from the lower shifter? It looks like two pieces so I'm assuming it comes apart.
What shifter you asking about?xjguy98 said:anyone know how to separate the upper shifter from the lower shifter? It looks like two pieces so I'm assuming it comes apart.
langer1 said:Should be a setscrew on the passenger side to remove.
langer1 said:Slide the cover up and remove the lock screw.
No I see yours don't have a cover, yours just pull off, it may be rusted though.JeepSpeedRacer said:Langer1,
When you say "slide the cover up", do you mean cut the weld? Have you done this?
JeepSpeedRacer said:The shifter handle is in two pieces. They must be separated to replace the lowest two boots (NOT the boots you can see when your interior is in tact).
The FSM gives no instruction on separating lower from upper.
See below:
I don't know if the BA10 is the same as the AX15.
If it is, then you need to unbolt the shifter and pull it from the trans, put it in a vice, and use two hacksaw blades (or two pieces of flat stock about that size) and slip them up in and release the clips, then pull or knock it apart with a mallet.
