- Camden, SC
I doubt I can make it. Still trying to get the windshield issue solved. I replug welded the rear but have yet to test that. And hopefully I will get the winch flipped soon.
we need to play in the pit again.Ghost said:I doubt I can make it. Still trying to get the windshield issue solved. I replug welded the rear but have yet to test that. And hopefully I will get the winch flipped soon.
you must have the famous RE HD trac bar bracket.....go ahead and weld it to the "frame" its the only way you'll get the thing to quit moving. take it off first and weld a couple of small gussets to the back of it connecting the upper part of the bracket to the lower part, you'll be glad you did.Mark WNC said:I might be up for Beasly too If I can get my trackbar
bracket tightened some how.
I thinking about welding it to the body.
Bolts tight, but it keeps moving.
That's for September 4th right?a-mechanic said:So its a go. 8:00 a.m. at McD's. eat breakfast and talk for a few mins and head out at 8:45 a.m. sharp. I can't wait.
