Selling the XJ....TN
96xjeeper
After MUCH thought and re-thought I have decided to take a jeep savitcal. This is mostly because of time constraints, and partially because I can use the money the jeep eats just sitting. So here it goes I am asking $3700, it is a 96 XJ country model. The jeep is located in Clarksville, TN. It has over 110,000 miles, it is hunter green, has some trail damage. THIS IS A TRAIL RIG, I have a clear title and all. IT would need to be trailered as I have MANY parts needed to roll not installed. I would be willing to deliver within 50 miles of Nashville, TN at the cost of my Diesal Fuel, but this would not be untill after Dec 1. I do have ALL parts needed for a capable trail rig, just no time to work on it. Don't get me wrong this jeep needs some TLC, but does run, that is why I am selling, I don't have the time for the care it is needing. Alot of the listed parts are NOT installed, and I WILL NOT PART OUT. If you have any questions or want to see pix email me at [email protected] or PM me here. It is all or none. here is a basic list of what it has:
List OF Jeep Parts Installed Not Installed
3 inch superlift lift w/ aal
2 inch poly coil spacers
.75” rusty’s extended shackle
1 inch steel lift block
Ranger main spring added to spring pack
2 inch aluminum lift block
2 inch short aal
2 inch steel coil spacers
Rancho LCA’s for 3” lift
Rusty’s 1” T-case drop
5-31x10.50 BFG AT/KO on chrome steel rims,1-31x10.50 BFG AT (old style) no rim
Winch bumper and stock front bumper
AJ’s Armor Rock Sliders…2x4 custom…3/16 steel
Dana 30 Dif Guard
Front steering skid
Tcase skid
Fuel Tank Skid
1.25” receiver hitch
2-Red Top Optima Battery
D35 Trac-Loc carrier
Dana 30 Lock Right Locker
D30 Carrier for 4.11 gears
4.11 gears front and rear
D30/D35 install kits
Spare D30 Hub assembly
CB and antenna
Hood vents
Home made Roof rack
Stock Sway bar and end links
Notes:
All Carpet removed
Front R&P done for, rear drained
Tranny Leak
Front Diff disassembled
Fender Flares gone, fenders trimmed, rock guards gone
Minor trail damage
