Selling some parts
bhicks
Forest Falls, CA
It's close to summer and time to clearn out the garage. Meeting people at So Cal fest allowed me to get rid of most of my extra parts but I still have some left so here ya go:
-Oil Pump for my 2000. Not sure what other years it will work on. Brand new still in box. Would like $40
-Fan clutch with about 10k miles on it. Would like to get $20
-1 Wheel hub assembly. Came off an 06 Rubi 44 but will work for any d30. I only have one. The other one was damaged. $30
-Coil pack for 2000-2001 in good working condition $20
-Motor mounts from an 01 in good condition. $10
-I'm sure more will come up as I do more cleaning.
I'm willing to ship but that cost would be added to the part cost.
BTW these are all obo. I also found a stock d44 diff cover and an autozone thermostat new in box. Let's say $5 for each of those.
This weekend I plan to acutally clean everything out and should find a lot more stuff.
I might be interested in the hub assembly, I am starting to have sqeaking. Ill have to look if it is my brakes or not.
I was really hopeful you would need something because I may be in need of your skills. I ordered my new winch and want to weld up a reciever on my front bumper. I have a rear reciever and the universal mount system with handles. I plan to run the wires and connectors soon but can't do much without a front reciever. I will probably have to toss in some cash with it as well. Let me know if you would be interested. If your too busy right now, I would be happy to ship the unit bearing out to you.
Motor mounts are spoken for.
Looks like Max doesn't need the unit bearing/hub assembly so it's still for sale. Also found some tow hooks I don't need any more. bought them for my TJ then never used them. I will attach a link of what they look like and where I got them from. How about $10 for the pair. Don't have the bolts.
http://www.summitracing.com/parts/WRN-13230
Also have a ubolt kit for a D44. They are longer then stock. Used them when I ran my deaver pack and they still had about 1" thread left. When I went with the full traction springs and 1.5 degree shim/block they were too short. Should be good with any aftermarket spring pack as long as you don't run a block with it. This also has the plates, nuts, and washers. How about $15 for the kit.
Tow hooks are sold.
What's left:
D44 u-bolt kit, unit bearing/hub assembly, fan clutch, oil pump, coil pack
Unit Bearing/hub assembly is sold.
I have the fan clutch, oil pump, coil pack, and d44 ubolt kit left
i will take the D44 u-bolt kit. making it down this way anytime?
Just went out to make sure I had all the nuts and washers to go with the u-bolts and plates. I found that one of the nuts was missing. No idea where it went. I also decided to measure their length and discovered a huge error on my part. The inside diameter on these is 3". If I remember correctly that is the inside diamter of the 8.25" axle and not the d44. I thought these were off my d44 when I had my deaver pack but now I think I gave those ubolts to someone on this forum. These bolts must have come off one of the Jeeps that had a lift put on in my garage, because I have never had an 8.25" axle. Maybe I am wrong, but I am pretty sure the d44 has a 2 3/4" axle tube. I will try and look into that later. What's odd is that these are still longer then the factory length so I'm really confused right now.
Just did my homework and found out that the d44 DOES have a 2 3/4" tube and the 8.25" has a 3" tube. I know the factory length of the 44 u-bolts but don't know the factory lenght of the 8.25" so I'm not sure if these are longer or not. I did put them up to my 44 and they were plenty long for my full traction pack if I didn't have the 1" block. Since I goofed they are now free. Please understand the u-bolt kit I have is for an 8.25". If someone needs these let me know. Sorry for the error.
I'm down in Yucaipa, Redlands, Mentone, and Beaumont rather often if that helps. I am also in Ontrario and Rancho Cucamonga quite often visiting family.
If Ryan doesn't get them, I will take them.
