selfmade leak down tester
Thanks for the quick reply Ehall.
Yes you are right, most of them are with 2 gauges. (My compressor has already one.)
But with one, it will work also perfect. When I put 100 PSI air into the cilinder,
shut off the valve and can see at the gauge or there is a big leakage.
But the most important thing is to listen to the engine. :listenmus
