Scary Frt Leaf Sping XJ
ROBZ95Xj
Keene NH
seen this rig around but finally got a chance to see it up close at the local mud bog, looks like a 5 year old did the work, its sittin at 10"lift up frt and 8" out back
crasy1_69 said:
That looks a little scary. Is the front mount setup in single sheer? The rear mount looks a little weak also.
it was double sheer, looked like he welded some steel plate to the unibody, drilled some holes and called it a day
The GREEN Pitman arm is pretty cool tho..:looser:
And "sheer" strength is way overrated, who needs it?
