Lowrange2
- Abbeville, SC
Swapped out the front drive shaft in the morning (fixed every single vibe problem I was having) and drove two hours to The Gultches. Paid to get in, turned on to the first trail and this:
Apparently even 760 joints don't hold up well either. Thanks to everyone that helped out and screw the only person that had a spare and wanted $100 for it. For any of you wondering, it's fine to drive 2 hours with a sock stuffed in your axle tube.
Is that not a 297 Joint? It says 297...
I wouldn't be scared to run alloy shafts. I've never broken a ring a pinion with alloys.
He is in/near Irmo? I'm pretty sure he is a friend of my uncle. I was supposed to check out that rig last time I was down there.
Yup, that's him. HIs 18 yr old daughter drives has a V8 ZJ on 35s with a bright pink warn winch on it. lol
