Safari Snorkel in a 1998 Sport with ABS
kndrewa: Thanks for the pictures. Never tought in put the bottle under the other side. I will try it. Thanks again.
I see that you reeplaced the D35. What do you do with the ABS system?
No problem, happy to share!
I pulled the fuse from the PDC to disable ABS for now, and have gutted the wiring to each wheel. I've been meaning to remove the pump altogether, but haven't had the time. To be honest, I'm not that familiar with modifying brake lines, so I haven't done the research. Once I do, I'll be putting my WARN solenoid in that ABS location. My winch solenoid is jammed up by my heater core/PDC right now, and a pain to get to for recovery situations, but it works.
Thanks a lot!!!. One of the last things in my Todo list is add a winch. That will mean to find out a place where to put another box or spend almost twice and buy one with the solenoids included.
