s-10 leaf packs
doesnt matter if its from a 2wd, but cut the ends of the longest leaf and put it under your jeep leaf before you put anything else under there, since the s10leafs have so much more arch and are more heavy duty than the stock jeep stuff. Adding small leafs with alot of arch will just invert the jeep leaf eventually. And you can use just about any 2.5" leaf w/ a 5/16" center pin
Get the 4x4 ZR2 if you can. More arch in the spring.
