Rustys 3 inch springs, Hitch, Wheels and Tires...
Alex E
Hey guys, I've got a few things for sale.
Rustys 3 inch coil springs, Good Condition and less then 2 years old. Reason for getting ride of them was I upgraded to 3.5 Rubicon Express springs after installing a bumper/winch and needed something to level out my Jeep. Asking 80 and can drop off or meet up if local, if interested in and you are in Sac OR Reno I may be able to drop off because I go to Nevada every 6 weeks or so. FYI 99 new plus shipping.
I also have a Draw Tite hitch, THERE IS NO HARDWARE! I used grade 8 bolts with large washers and nylon nuts to mount it. Worked great but I upgraded to a custom rear bumper. Great hitch for towing or tow point. I'm asking 30 bucks and if you really want I'll even go to the store and buy all the correct hardware I used and I'll add it to the price. I believe I spent less then 10 bucks on all correct hardware so 40ish for it complete? I can drop that off too.
I also have my stock wheels and tires from an 87 XJ. The rims are in good condition BUT some one has sprayed them black and did a crappy job. Two tires still have tread and the other two are at the wear bars. They are 15 inch rims, also have spare tire and rim as well. The spare rim is the same size as the other 4 but its white and a different style because its a spare. Basically I'd give these away for 15 or 20 bucks, really if anyone has any use for them just let me know and I'll be happy to get money to just cover gas and maybe a coffee for the drive.
Last but not least I've got an open 44 carrier, open 30 carrier and two matching sets of 3.55's. If its of any use to someone just let me know.
correct, so if you want 3.73 and up then you will need a different carrier but it works with 3.55 and down. FYI when i installed 4.56's i got a fresh carrier from randys ring and pinion for 58 bucks if people need a quick way to get one.
