jro780
- Des Moines, Iowa
I have a '99 XJ Limited 4.0 Auto w/ approx. 235,000 miles on the OD. The engine has been very reliable but has developed a hesitation about 30 seconds after start-up. It does not matter if the engine is hot or cold, or if the outside temp is hot and cold. The engine starts great. After 30 seconds it runs incredibly rough for another 30 seconds, then it is just fine. If you accelerate while it is running rough, the engine will pop (like a backfire coming from the throttle body) and then runs fine.
I have researched many, many posts to no avail. I have new plugs, cap, rotor, and have cleaned the IAC. For different reasons, I have also replaced the water pump and thermostat. I also do not believe that it is an issue with the fuel pump. Even if I turn the key on for 10 seconds 2-3 times before starting I still get the same result.
Any guidance is appreciated. Thank you.
