Running ARB locker off of ac pump air compressor
Jeepguy91
Warsaw, IN
Looking at picking up a used ARB air locker for my Dana 44 front axle. I have converted my ac pump to be my air compressor with a 2.5 gallon tank sitting back in my cargo area. Will I be able to use my air compressor setup to feed air to the locker? Been trying to look around to find someone who has done it before but no luck so far. Any insight on how to do it would be great.
Thanks,
Ben
Sent from my XT1565 using Tapatalk
Absolutely!
Right now the pressure switch I have is on at 90 psi and off at 120 psi. Tank wis rated for 150psi.
I believe ARB lockers specify 80-90 max psi so you either need a regulator or a lower pressure switch.
