- Roanoke VA
Mine are on order!!!!
XJEEPER said:I'm running one on my rear D44 and they are beefy. If you can dent one, you'll have bigger issues to worry about.
This being said, mine leaked diff fluid through a welded seam when installed. I contacted RuffStuff via email and voicemail when the leak was discovered, never got a return call or email. I pulled it off, tried to locate the culprit seam and reweld it from the inside. It still weeps a little fluid, so I'll try again on the next fluid change........
They build tough stuff, but Customer Service needs some improvement. I don't think a $100 diff cover should leak..............:dunno:
cdhowell said:I buy these covers from Dan and the only issue I have seen is with the Rubicon 44. The cover hits the air line inside. Very minor and an easy fix but something to watch. Good all around product.
Gravel Maker said:Try a phone call, we sometimes get 400 junk emails a day.....No it should not, we can replace it.
xjtrailrider said:Anybody running them? Do they hold up well in the rocks? I'm going to order the 8.25/D-30 covers with the drain plug and countersunk bolts. I plan on shaving the 8.25 and I know the stock cover is gonna peel and I haven't seen any guards that I'm as impressed with as I am these covers.
http://www.ruffstuffspecialties.com/catalog/chrysler-825-375-one-piece-diff-cover-p-152.html?osCsid=ecd9d1f9e7160a2b51490c78d760e0e9
http://www.ruffstuffspecialties.com/catalog/dana-30-375-one-piece-diff-cover-p-151.html
xjtrailrider said:You will need a 3/4" allen key for the fill plug as well.
