89TrailXJ
- Grand Blanc Michigan
Correct, on the HO motor XJ's you can ground the #10 pin in the connector under the dash and do the same thing. Unfortunately, its only the HO based XJ's, so I have to do a throttle hold to do the same for running my OBW.evilpresence said:I read somewhere (but not sure) that the extended idle switch is found in the police package equiped XJs. I may be mistaken but I believe when on, your engine runs at a 1000 rpms higher.
Just my 2cents.
