BoringDave
- Boring
makes since! It does ride alot smoother and will flex like mad now. I used my new deg. finder it says the caster is about 5 deg. I also checked the drag link and track bar they are about 11 to 11 1/2 deg. I do know they need to be very close to the same. But before it just had a stiff ride with sharp predictable bump steer and the steering was tight feeling. I didn't even have to run the sway bar. Now it seams like it has a mushy feel in the wheel and it leads me all over the road I have to work the wheel to drive straight. I am thinking I need some more + caster and toe to force the jeep straight down the road. I also did some measuring of the control arms. The ones that I got when I bought the lift will fit. I will have to install them at the most negative setting and go up from there.
Dave
Dave
