bcmaxx
- The West Kootenays,B.C. Canada
Hey guys, i have a problem here. I have exactly 4.5" lift up front and running the drop brackets. My issue is obvious:
The axle is too far forward, tilting the spring (upper coil is not seated correctly on coil spacer) and making the sway bar link bracket hit the coil spring.
What can i do to solve this? I love how it rides but concerned about this issue.
doesn't look like ur arms are correctly adjusted. mine took a wee bit of tweeking.
try sucking the top in a bit or lengthening the lowers a tad- not much though
