5150caz
- Victorville, CA
Hey guys I'm at a loss and need help. I bought RC drop brackets for my jeep and installed. Once the I got the brackets on I noticed the passenger side coil spring is bowing in the middle to the front like the caster is off and hitting my sway bar and the upper bump stop is touching the back side of the spring (that's how much its bowing). The driver side is perfect, straight up and down, upper bump stop is in the middle. My control arms are Rubicon Express none adjustable (same length as stock arms top and bottom). What the heck could cause this? My dana 30 has the vacuum disconnect so I was thinking, could the axle tube on the passenger side have twisted in the housing? When I bought the jeep 10 years ago the guy said it was hit on the passenger side but there was no frame damage and is was only the fender and tire hit. Please help.
