truckerdirt said:
it's an 89, not 98 as she originally posted here. actually, the second post in this thread is from her stating that she mistakenly put 98 instead of 89 in the original.
richp, thanx for the advice. i do not and will not use teh hobby shop here at elmendorf, but i may eventually use one at our neighboring army post. also, she doesn't yet have a transfer case, or front diff, since this is only a 2wd model, for now.
2WD in ALASKA, geeze what did the original owner do or who'd he piss off to get transfered from mcdill to elmendorf
The only place I ever saw 2wd XJ's was out of florida.
I'd advise you look at a traction device for that rear diff like an auburn or trac lock for the winters up there cause I know how mine handles in 2wd with even light dusting of snow here in Pa. I'm curious how it will handle now that I have the auburn in there, got it last month
and it's pretty cool off road..
There have been a few that have done the conversion, all the mount points are there, all you need is a donor vehicle, try to find one without the vacumun disconnect front differential, 91 and newer I think. Grab all the parts including linkages, front springs and even the console.
I saw one really determined guy up here do one in a weekend but he also had the donor 30 ft away, was a rollover 95 and his was 95 he picked up here originally from florida.
I am serious about the stock parts though, don't use any fancy stuff till you find out whats what, the XJ's run just great on dealer supplied Champion plugs and Mopar does have an 8mm high performance plug wire thats about $10 cheaper than the stock OEM plug wires, just one of those strange things.
Also anytime you take a bolt off put antisieze on when reassembling. Buy a case of powerblaster and soak any planned parts removal about a week ahead of time. Use dielectric grease on all electrical connections including the plugs and cap. If you clean the throttle body out with a spray cleaner keep the cleaner off the plastic sensors in the throttle body or you will be replaceing a throttle position sensor and MAP sensor in short order. Better to remove the throttle body and clean it on a workbench, takes 10 min off and 15 back on, take a picture or make a drawing of what goes where...
If you pull the valve cover have a shop vac handy, if there is alot of sludge build up in there the stuff will break loose, use the shop vac in one hand an a plastic scraper in the other in tandem, you don't want those small pieces of sludge getting down into the return passages and into the oil pan where they can block the oil pump pickup... It is also a good time to clean the CCV system, specially if you have any oil in the air filter, if so you will need to either clean or replace those CCV parts and tubes... Thats about all I can think off off hand, any more questions feel free to ask.
Alot of the stuff can be found with the search function about specific questions though there is alot of stuff to sort thru. Another good thing is to find a Factory Service Manual, they are worth their weight in gold. The chiltons and Haynes manuals are pretty much a waste of money. The FSM's are the size of a city phone book and just cover YOUR year and your model, not 10 or 12 years and 8 different models. Sometimes you can find them on Ebay, I have two, one for the XJ and one for our two TJ's.
