I'm sure you've posted them before, but what are the specs on the new build?
That's not saying much; didn't Alex win it last year? :roflmao:Between you and Opie you may give Michael a run for his money on the "Built not Bought" award.
To help get things back on track a little bit.
I do all of my own work on my rig and fab everything I can, or at least that it makes sense to.
Front bumper and grill guard all home made (holds 5 gal of compressed air).
Rear bumper (holds 7 gal of compressed air).
Rock sliders with 4 arms and 20 attachments at the seams.
adj. UCA's home made with JJ's at frame end and stock bushing at axle end.
adj. LCA's home made with JJ's at frame end and stock bushing at axle end.
adj. TB home made with Heims at both ends (above the axle brackets all home made and frame mount home made).
over the knuckle inverted Y steering home made with Heims.
Hybrid Cage designed with expert help from family and friends and built with expert help from friends at home.
Rear leaf pack bastard pack home made with a mixture of 3 sets of springs.
Rear bump stops home made.
Rear shock mounts moved up on axle.
Front bump stops home made.
Rear storage shelf home made.
Rear storage drawer home made.
Tube air intake home made.
OBA from A/C conversion.
rotating (4 Hella) light mount on top of halo home made. (Also known as Blazing Sun of direct blindness in TTCW teammate's Rear View Mirror)
Custom front seats modified to fit.
Front skids on axle.
Numerous gear installs on this Jeep and others. (I have been very happy with my Yukon gears and Johns install on 1 set of Yukons for me).
HD 231 with Chevy upgrades from junk yard and short shaft kit.
Modified yokes front and rear to accept U-bolts instead of straps.
My own tire and wheel installs.
Rock lights installed.
H4 conversion installed.
5 point harnesses installed.
> Rocker Replacement square tube - installed on Thrashed Metal
I am sure I am missing something, but you get the idea.
Michael
PS. Scott, although I did modify that rear D44 cover I don't want to take credit for the bulk of the work that "JB Weld/OD XJ/MEGAWATT" did. Plus his fab skills are MUCH better than mine!
Jeremy!!! How many User names have you had?
-----Matt-----
I know Michael won the "Built not Bought," and I think Alex won some trail hero award.
There was a "Bought not Built" award, but I can't seem to remember who won that... :dunno:
Your sarcasm filter is flat busted.Did Matt get the bought not built?
Guess what's next.
Baby first, then a cage. :hang:Soooo...when do I get you go to your place to build a cage?
~Scott
Rich
Rich
Thanks Tracey. I forgot a couple also. Painted both inside and out and tube fenders both front and rear.Metal Thrasher said:I added a couple
Built several of my own and many here.
My most recent mod:
We want the Elbe pics and video, John.
-Alex
My current winch bumper build. Pics are as of yesterday.
I'm hoping it should be pretty low profile. It only sticks out 3" further than my old one. I still need to angle the sides in, and cut out a few filler pieces for the top.
