bigthorp420
- lala land
Hey, I need to find out where the +12 source for the reverse lights originates from for a 1996 Cherokee. The vehicle had a fire so everything was rewired. Prior to the small fire/short the reverse lights were working, so I am going to assume that the reverse light switch on the AX15 is still working. We have the wire for the reverse lights at the driver's side kick panel, but are not sure where it runs from there. I know the reverse light switch is a 2 wire system but are not sure exactly how it controls the reverse lights, and if the reverse light wires connect directly to the reverse lights switch on the trans or not.
Any help is appreciated, as this is the one of the last wrinkles to iron out!
Also if anybody has any knowledge of what wire out of the OBD2 computer controls the electric fan....although that is less important at the moment as the fan is currently hardwired to a switch.
Thanks in advance!!
Thanks in advance!!
