O-Gauge Steamer
- Colorado Springs, Colorado
OK, here is the place for discussion on limiters.
A fuel cut based rev limiter has been in use for decades on force induction engines and I even hit fuel cut on my Starion at close to 3 bar. According to the log 37.5 PSI is where the ECU cut fuel and logged 0 knock events as a result. So why didn't my engine "Lean out" and detonate?
I know why, but I want to see if anyone else knows why.
The fuel cut so there was no more fuel to detonate seems like the obvious answer. Yes, an injector could have just started squirting during a fuel cut, but hopefully the PCM is not dumb enough to cut fuel in the middle of a squirt. Fuel cuts after a complete squirt with that cylinder firing fine and the rest just get air to do nothing with. Assuming the PCM is smart like that then it makes sense to cut fuel only and finish any injections it was in the middle of doing.
Flying Ryan Tuning has been flashing stroker pcms over on Jeepstrokers with great reviews.
This.Reflash the ECU to have a 4,856 rpm limiter, problem solved.![]()
