Replacing the front fuel line
snail
North Jersey
Hey guys, I hope everyone has been well, it's been awhile..
Anyway, I need to replace my front fuel line which goes from the frame rail up to the fuel rail. It has the quick disconnects / rubber on both sides and hardline in the middle.
I would like to replace it with an OEM part, but I'm getting conflicting results.
1.) I need the line labeled as #1 ( 52100138AB ) from the schematic below.
2.) One Dealer said that it no longer comes as a hardline, and that the "bundle" is a length of rubber hose, quick discos, clamps, etc, that you need to assemble yourself. (which defeats the purpose of me trying to get an OEM hardline).
3.) All the other local Dealers are clueless, and since it's a relatively expensive order-only part, they want me to pay upfront, with no refund if it's not the part I want.
3.) I was in the middle of doing this fix method today: http://www.cherokeeforum.com/f51/leaky-fuel-line-fuel-rail-replacement-fix-170244/
but decided to stop because I don't like how the rubber hose I got is ran, nor its temperature rating that close to hot components.
Long story short: Does anyone know for sure if I can still get this OEM replacement hardline? A clarifying part # or recommended website to order from would be great.
1997 XJ 4.0 4wd btw
Wild guess but have you checked Dorman or Rock auto for an OEM style.
I haven't had a problem finding the part, it's just that I wasn't sure the part included a hardline section or not, based off of what a Dealer tech told me.
The '97 fuel line, part number 52100138AB was superseded by the '98 fuel line, part number 52100137AE.
http://www.moparamerica.com/oe-mopar/52100137ae
Thanks Sidewinder, I may just try that one out then
