GreatOdin'sRaven
- Las Vegas, NV
I’ve been chasing an overheating problem going on three years.
Jeep overheats at idle.
Every summer my Jeep overheats, I change parts all summer and never fix it until the weather cools down and the problem goes away.
2018:
-moved to Las Vegas and my overheating problems begin
-replace every cooling system part one by one with cheap Chinese stuff.
- find leaking head gasket in Oct, repaired it
- head checked for leaks/cracks, replaced with felpro gasket using new bolts.
2019:
-overheating begins around May
- replace each cooling system part (again) one by one, but with OEM or better parts
- chase problems down all summer until weather gets cool
2020:
- overheating problems starting again this week
- super cleaned my AC condenser
- Still overheating at idle
Here’s what I’m running/replaced - (consider all parts brand new and less than one year old)
**RADIATOR**
OEM from AutoZone
Silicone hoses top and bottom from Amazon
**FANS**
HD fan clutch from Napa for ZJ
Low profile 10 inch E fan (turns on at 218 F)
**WATER PUMP**
Flowkooler high flow water pump
**THERMOSTAT**
Super Stat 180 degrees
Hesco High flow thermostat Housing
**OTHER**
-Cleaned the AC condenser for about 3 hours
-I’ve ran Preston flush more times than I can count
- My heater is not by passed (heat works fine)
- I’ve ran compressed air through every hose backwards and forward multiple times
- I don’t have that stupid spring in the bottom hose but doubt that’s causing my problems
- i verified it is actually overheating using a IR heat gun pointed at thermostat housing
Any help is greatly appreciated. I am about to drive the Jeep off a cliff. I am even desperate enough to take it to a mechanic at this point.
Please help.
2018:
2019:
2020:
**RADIATOR**
OEM from AutoZone
**FANS**
**WATER PUMP**
**THERMOSTAT**
**OTHER**
Please help.
