replaced EVERYTHING and still have no brake pedal
BPB
I am out of parts to throw at my brakes. Not that it should effect anything but I have 3/4 ton chevy brakes upfront and 3/4 ton ford brakes in the rear bth front calipers are new as are the rear weel cylindars. I just put a new master cylinder in it today. Yes the master was bench bled. I bled about a half gallon of brake fluid through the system with a power bleeder. I tried pumping between bleedings. I replaced the load sensing proportioning valve with a T. My rear brakes are over tightened, so I know that is not the problem. My lines sat disconnected for about a year and a half. Could the return line from the rear having air in it be my problem?
