To those people who have actually replaced a 2000-2001 cracked 4.0 head after running it 800+ miles or more with coolant in the oil:
I have a 2000 Grand Cherokee 4.0 with 140k miles. I have been feeding it coolant over the past 6 months, and I have only driven it about 800 miles over that time (this is not my daily driver, but I like it when I need it). I have put in about 4 gallons of 50/50 coolant total over that 6 months. Then, oil dipstick showed 2 quarts over-full, chocolate milk-shake. Oil cap had green foam on underside...
With a fresh oil change this week, my oil pressure settles at 19psi after: 15 min warm-up idle, driving it 6 miles, then letting it idle for 10 minutes. Engine sounds great at idle, at 4000 rpm, and even under load of acceleration. No knocking, no anything.
Rather than swap the engine, I am planning on a rebuilt TUPY head replacement. So, I am asking: has anyone had their bearings fail AFTER replacing the head, in an engine that held 19psi oil pressure at warm idle before the head-swap? If so, how long did the bearings last AFTER the head swap?
Thanks,
JohnEP
Thanks,
JohnEP
