5-90
- Hammerspace
mattbred said:What? 5-90, me, and a bunch of others have completley blocked off the EGR with no ill effects. I think 5-90 says it actually made his put out less emissions. There have been absolutely no side effects to it other than a more reliable engine..
Like I said earlier, there is something extremely wrong about stangrcr1's engine. Maybe distributor play like that other guy said?
Also that's the first time I've heard of "Renix is known to run lean and thats why the exhaust manifolds crack". As far as I know, the manifolds crack on every single XJ (87-01) just as commonly.
Not trying to be offensive or condensending, this is just my experiences/what I've heard..
Stangrcr1, perhaps you have a big vacuum leak? That can cause a motor to run lean. You don't get any high idles do you?
Hey, when's the last time you changed your timing chain?
I have got to dig up those "before/after" tests on my 87 from right after I got it - it damned sure did run cleaner with the failed EGR valve...
And, as I understand it, the common "header cracks" in the XJ and MJ are more often due to failed/failing engine mounts, and the lack of a flexible section in the downpipe (between the collector flange and the first exhaust hanger at the crossmember.) This is per "reports from the field," and nothing official.
