Black_Black
- Colorado
Since I've owned the jeep, it does a good rev on startup then settles down to 1000-1100rpm. In gear it will hold 700-800rpm.
I have been through dozens of IAC's over the years and the TPS is currently brand new and adjusted properly. Trying to figure this out I installed a fully extended IAC and did not plug it in. It starts up nice now no rev but within 5 seconds it climbs back up to 1100rpm idle with the computer still trying to close it even with it fully closed. Seems like there is extra air coming from somewhere. I don't think there are any vacuum leaks I've checked everything with a propane Torch.
I'd like to check the intake manifold bolts can I get in there without removing the fuel rail and everything?
