They seem to vary a little, but on at about 185 to 190 F, and off at about 168 to 172 F, measured with IR at the sensor in the cool side of the Radiator. The temp at the thermostat housing can be 15 to 50 F hotter depending on the coolant flow rate through the entire system (think loose pump impeller, loose belt and partially clogged radiator, versus new parts). I did a special write up on here 2-3 summers ago. I went to a manual toggle switch on mine before I upgraded my entire cooling system.
The HO system uses the "thermostat housing" temperature location for the data signal to power the E-Fan, which was an improvement, especially if the flow through the radiator is real slow!!!!!!!
I discovered that the delta T across my radiator dropped from 35 F to only 15 F, when I replaced the radiator, and yet the engine peak temperature dropped 35 F under the same conditions. I scratched my head over that data, and then it dawned on me that the key change (which none of us can easliy measure) was the actual system GPM flow rate through the radiator and engine with a new (nor partly clogged) radiator.
The old radiator was only 3-4 years old, 2 row aluminum, plastic tanks el-cheapo. I recently discovered that the other problem I had was a leaking E-manifold donut-flange at the down pipe joint that was heating the block, and adding to the load.
