Accept inside under the driverside kick panel.MOOSE16285 said:The "Renix Killer" ground, how can I get that off. I've seemed to lost my swivel joint for the socket and the wrench aint doing it? There's a "lip" on the fire wall that is stopping me from using a str8 extension socket. I might just pound the lip in that area back to get the socket in. The ground wire is covered in burnt engine oil...
Lemme make sure I got all the grounds covered...
1. Driver fender well
2. fire wall
3. dip stick bolt
4. battery post
That covers em all?!
I've simply ripped the braided one off and replaced it with side-post ground cable from autopats store. I've also ran it from firewall to the diptstick.wilcharl said:like 87manche said just run anything to try you would not even need to take the bolt out... im betting this will start your jeep
Around to it= roundtoitMOOSE16285 said:roundtoit? Whats that?
Anyway, I just got back in from being all day out there working on it...
Got the renix killer replaced w a sidepost cable. Cleaned em all out good. And went to crank it...
Nada... Nothing at all. Now I got a leaking fuel injector. So I'll get back to it later. I'm hungry... Time for some beers and food at the local sports bar...
