remove and replace "C's" on a D30?
peterjford
Yorba Linda CA
This probably belongs in the modified tech section, but I am going to need to hire a local welder to do the work so I am putting it in here for now.
Is there anyone here that has the welding skills to do this? How much do you charge?
I am looking for a D30 housing with everything straight, but I might be able to get an D30 with straight tubes but bent "C's". I am pretty sure mine are fine so while swapping everything else over, I could have those swapped too. I am also at the limits of the upper and lower control arms adjustability and this would allow me to set the caster and the driveshaft angles properly.
Dallas can probably do it for you, but he's here in Escondido. He did mine on a D44 a while back.
