Regearing Questions? READ THIS!
Paul S said:
I don't drive it much anymore, but it was my daily driver for a long time, including a lot of mountain driving. I remember when I went from 33 to 35's I thought that the 35's were better suited to 4.56's than the 33's were.
Paul
Was your impression of fine before or after the anorexic period? Heaviest, lightest, current?
Back to the Top for this excellent thread since we seem to have a fresh crop of newbies with dreams of big tires on small budgets.
CRASH
Just to add to this wonderful thread, here is the list of lowest gears available for the most common axles:
Dana 30 - 5.38
Dana RC30 - 4.88
Dana 44 - 5.89
Dana RC44 - 5.38
Dana 60 - 7.17
Dana RC60 - 5.38
Dana 70 - 7.17
Dana 35 - 4.88
Ford 8.8 - 5.13
Ford 9" - 7.33
Currie HP9" - 4.88
TrueHi9 - 5.38
Toyota 8" - 5.71
Toyota HP 8" - 5.29
Chevy 14 Bolt - 5.13
Chrysler 8.25 - 4.56
Ford 10.25 - 5.13
AMC20 - 4.88
Billy
old_man said:
It's funny how everybody has a different opinion. I run 35's w/4.56's and have never really needed a lower gear, except when I was running a stick. I now run an auto and a 4.7L stroker. Lower gears would be nice, but I was doing a bit of freeway running with it, so 4.56's were a good solution.
.456's w/35's yields a virtually stock overall drive ratio.
Thank you for that.
I have a H.O. and 5spd and was going to go 35/4.56, thinking it would be a little deeper than stock.
I'll be keeping my D30, but swapping in a D44 from my parts jeep when gearing time comes. (35's and 3.07's for a few weeks ought to be interesting...)
Hmm, now to decide on 4.88's or even 5.13's.
Time to Google an RPM calculator.
On that note, add a good calculator to the gearing sticky.
According to 4Lo's gear calculator, 35's with 5.13 gears, .78 OD (5th gear guesstimate), and 1:1 TC ratio, I'll only be turning 2304 RPM at 60 MPH.
That is very do-able.
With a 30 front you made your decision. 4.88's are as low as you can go.
Yes, it's a 94.
Well, for lack of a better choice, I can live with 4.88, and go to a lower gear set in the TC if I find I need to.
I was considering that anyway, since I have a stick.
Thanks for the education guys. :)
Back to the top so as to compliment the axle thread.
CRASH
ok - anyone know the stock gears in the:
1986 comanche pickup with a 2.8L V-6 and the AX-5 and hte 231?
TIA (im looking to buy this rig) - but dont have it in front of me...
I think those were 3.73's but don't hold me to it.
Add a little more since the oil people are hurting this month.
For those of you that are concerned about the right gears hurting your mileage, I'll provide a little example.
'89
Swapped in '95 motor running non-HO electronics with the HO intake and TB.
Ported and Polished Head.
Some kind of cam that seems too hot
AW-4 with the .705 OD
5.38 gears
35's
Somewhere around 6" or 7" of lift
80 mph revs around 2800
I'm averaging 16 mpg of a mix of highway and trail. With 4.10's and 33's I got 14-15 with everything else the same (I can tell you from experience that is a very shitty setup :D)
I know Crash did the numbers for general gearing, but I needed to know specifics for my application so I came up with the following for anyone who wants to see what numbers look like for the BA 10/5
RPMs for 33" tires and 4.88 gears. My BA 10/5 is mated to the NP231 and an 87 Non HO 4.0. Following Eagle's statement that the BA has a .72 overdrive I calculated the following numbers for 33s with 4.88 or 4.46.
4.88 @ 70 MPHs = 2504 RPMS on 33s
4.56 @ 70 MPHs = 2340 RPMS on 33s
For my application as I will only drive on the freeway to the trail, I have decided to go with 4.88s.
